need help: rear winch? no armor
goohead
need some advice on this subject,
looking to be able to tow some cars that are not drivable, and I need to install a winch of some sort to the rear of the 4runner. I do not have any armor or steel rear bumper and do not intent to get one, anyone know of any option or have done something similar?
ya i saw that one, I was planning to tow on a trailer/flatbed and was worried if i had this hooked up, soon as I try to winch the car up it might move the entire trailer instead? due to not beeing hooked up to the tow hitch.
I then thought maybe some stoppers under the wheel of the trailer, but I dont know if that will work.
Have you seen one like that but with an output for a tow ball?
Yikes! That's a tough one. You don't think a simple come-along would suffice for your application?
Or maybe hook a winch plate to the busted vehicle and snatch block to the trailer? That would be assuming that the vehicle has some sort of receiver and you can power the winch. I don't know, I'm just spit balling here...
You need a hitch draw bar (the part that slides into the hitch and has the ball on it. This draw bar needs to be long enough the also have a winch mounted on it. This way you can have the trailer connected and have the winch mounted too. The one issue will be, the winch cable may run/rub on the front of the trailer. You could protect the cable and trailer with a heavy mat or something.
Or. Have a small winch that hooks to the tow vehicle by webbing. This would allow the winch to work on top of the trailer.
I don't know if this will work since I am still in the planning stage but I am going to try mounting a winch on the inside of the back brace and enlarge the hole in the brace and run the winch through me have a hawse on both sides so the cable will stick out and the winch will be under the truck
Your desire sounds like my zackly. :)
It sound exactly like what I am doing.
I have a hand crank winch on one trailer and it wears me out pulling stuff onto the trailer.
It isn't too bad if it was just one or two pieces, but I may have a number to do.
I want a winch mounted on the receiver hitch and be able to have the trailer hitched up to it for pulling stuff on and towing. I have several tow vehicles and several trailers that I would like to be able to interchange.
I'm still trying to figure out what to do for recharging the battery. I am fine with just putting a battery in the back and jumper cabling some wires to the winch for power, for now.
I got a solid piece of 2" square metal that goes into the receiver on the vehicle. Slipped over a ways and welded onto the back end of this goes a piece of 2" i.d. tubing that turns the back end of this into a receiver hitch. I got 2 pieces of square tube about a foot long to weld sideways onto the square piece to mount the winch to. I think that the 2" up will be enough extra height to get the winch cable above the trailer hitch latch. If you have a larger vehicle with extra height, you might be able to use a drop down hitch so the ball and trailer latch would be lower anyway.
It looks like the total length might be about 2 feet long, I can't remember right now.
I hope that extra length isn't enough to really mess with towing the trailer.
I expect that there might be some slop in the two connections so a trailer could get squirrel-y.
I'm not going very far and I don't plan to need to go very fast so I am sure it will work for me.
