Need help removing front & rear driveshafts
gannonrt
I'm replacing my clutch and need to disconnect the driveshafts. I can get the nuts off of the front shaft but do I need to take the bolts out too to get the shaft off? On the main drive shaft I can't get a ratchet in there to get the bolts off. What have you guys used?
I used a ratchet wrench for the rear driveshaft on both ends. Had to use an impact with extensions and a swivel for the front.
mek
