Need help with a few minor issues.
bhunter2281
This may sound very petty to all of y'all, but I have no idea where to find the answers to these questions in this forum. I have an 06 SR5 4x4 if that helps answer any of these. If needed, I can upload pictures later today.
1. How should I go about replacing the rear brakelight above the rear windshield?
2. As of now, my driver door doesn't lock- the switch on the inner door handle is jammed in the unlocked setting. I tried to take the door panel off, but I feel like I'm going to crack every piece of plastic I try to pull out.
3. When I tried to take my running boards off, one of the bolts just keeps spinning and spinning... But doesn't ever come out. I did about 5 minutes of an electric wrench and there was no result. This makes me think that there is possibly a nut on the inside of the frame that has broken off and is just spinning along with the bolt. Is there any way that I can get in there and just undo the bolt from the top?
1. http://www.toyota-4runner.org/maintenance-detailing/23813-3rd-brake-light.html
2. http://www.toyota-4runner.org/engin...-idiots-guide-door-panel-removal-4th-gen.html
3. Apply some downward pressure when turning the screw to get that one off. It could be striped. But when i took mine off there were no nuts on the top side. they just screwed into the frame.
