Need NEW FRONT AXLES
Trdsupranick
Hey all,
Where is the best place to buy replacement front axles? Mine are leaking everywhere and the shop says you might as well buy new ones then try to "reboot them" because it is not much more to just replace them.
Is there any good priced web sites that offer OE axles?
Thanks!!!
Really??!! Is this due to your lift?? I would think just rebooting them is cheaper. Anyways, with a new axle, wouldn't you still have the SAME problem because you are planning on keeping your 3/2 lift, right?
Is this a legit shop?
You have to remove the axle to install new boots anyways so I think it is actually easier to replace the entire cv. Inner and outer boots were around $50.00 and a new axle with lifetime guarantee at O'reilly is $90.00. I would agree with your mechanic.
X2, Ive replaced a boot on my 99, Ive replaced a CV on the 99, Id much rather just replace the whole thing. Like racedirt1 said, go to Oreilly or NAPA and get the lifetime replacements.
Just my .02
Just my .02
Ahhh...good to know. Here is my question...his lift is probably the problem, right? So, this axle replacement will be a frequent occurrence?? :(
try Downey Toyota they have axles that are slightly stronger and ave more flex. you will have to call them they wont let you order online
I have an 04 4Runner, no lift, only 65xxx miles. Both outer boots are puking grease all over... Dealer told me it was a very common issue. They are going to try to re pack the boots, using a zip-tie to seal. If it does not hold, will have to do the replacement as well.
i have a 2004 V6 4runner 100k miles, with the same issue, grease everywhere, i just put on new clamps, hopefully that will last.
