Need some info about my 22r runner
CRANKY 4 RUNNER
hi all.
im new to the 4 runners i just bort a cheap 22r petrol runner
it has a fue problems but seams like it will be a great truck once fixed up just wanted to no a bit about the motor and car it self
it has a 2inch body lift a 3 inch suspension lift 35s and came with 33s and has front and rear detroit lockers
can someone give me a bit of info would be muchly appreciated :)
With a 22R, that should be a 1st Gen, so you should post in the "Classic T4R" section--lots of knowledgable guys with those around here. With a mechanical locker in the front, I hope you don't intend to do much street driving in 4WD (winter snow and ice, etc.)--that will really screw with your control of the vehicle, limiting your steering response and pushing you wide in turns. It will be fine if you're intending it for mostly trail running, though. Sounds like you've got enough lift for the tires--do you know what gearing it has? With 35's, you should be maxed out with 5.29's for proper acceleration, cruising RPM, and speedo calibration. Don't know much about the 4-bangers, but there are plenty here who do. Welcome to the forum, and best of luck!
Fuel Prob
hi all.
Hello, Your fuel filter is underneath ur intake manifold.You can loosen the fuel nut(17mm) crank ur eng couple times fuel should squirt, If not you hav a bad fuel pump which maybe in you fuel tank. If so gd luck 'cause you hv2 drain/drop the fuel tank. Kapeesh!
charlesz
