Need U-Joints for 2001 Limited 2WD
apache67
Hey Guys,
Please recommend a good brand-set of u-joints for a 2001 2WD Limited.
Thanks Much!
G
P.S. and yes, I did do a search, but can't come up with anything definitive.
Buy a good used drive shaft.
U-joints brand : TOYOTA
Oh that's silly...
Buy any brand u-joint from rock auto and replace it yourself (I bought Moog, though I'm not that big a fan of them; I think they are fine for u-joint bearings). If you don't have a press or anything else to use instead, go get a cheap one from harbor freight, they can be had for as little as $70 (plus you'll then have a press for other stuff too!). The u-joint isn't that hard to replace, I just did mine.
If you are a total novice with mechanical stuff, then maybe consider paying a shop to replace it, but price out the labor, and consider just taking the parts to either a mechanic to press out and in, or just take it to a machine shop of some sort that has a press and see what they would charge. Buying a new drive shaft would be the last resort as I am sure that will be more expensive than replacing the joint. Only do that if it turns out to be cheaper.
If you're willing to give doing it yourself a shot, I'll walk you through it. You can search for replacement instructions, or just look it up on youtube and you will find TONS of how-to videos, it's a pretty universal procedure.
Thanks Nelsonmd!
I am pretty mechanically inclined. My problem is time. There is a shop very near to my house here in Atlanta acctoyota.com/ that gets reviews. Maybe I will see what they charge in labor.
G
Thanks Nelsonmd!
G
If you are mechanically inclined, then you should be able to do it in just an hour or 2. I think I took about 4 hours, but I also painted the parts, and struggled with my typical massive rust problems. My second time through, I expect to do it in about an hour (assuming I ever have to do it again...). If you can find the time at all, I would suggest you go for it yourself.
I am not going to change your mind.
I'll tell my experience. I got a U-joint from NAPA and replaced the very last U joint as it is the one goes bad first. I was careful at replacing the U-joint, but at the end, it had a very small free movement when I try to hold one half by hand the try to turn the other half by hand. I then got a used drive line from a truck that had 200 K, and I checked it thoroughly. Absolutely no free movement in any of the U joints, not even a bit.
You clearly had something irregular going on, either a bad part, or some issue with the install. I don't think your experience is what most others have had as tons of people replace their own u-joints. Did the NAPA one come with a new spider, or was it just the bearings?
I am not expecting to change your mind either, since we always default to our own experiences, but one bad experience doesn't mean the recommendation for others should be to drop alot of money on a whole new DS.
I'm parting out a 4wd 96, if the parts are interchangable (you can verify through OEM part numbers), I will be picking it up Sunday and will be happy to pull the drive shaft and check it/ship it to you.
Best of luck with the repair
It came with new spider and bearings. No, not a new DS, but a used one for like $80-100 shipped.
BillM777
