Need Wiring Help - 2010 SR5 w/ Rearview Mirror Monitor
shilly
The previous threads showing the wiring for the rearview mirror show solutions to get 12 V ignition switched power from a mirror that only have 2 wires in the connector. 1) Blue (+) and White (-) on a connector with 2 rows of 5 holes. LINK and 2) Yellow (+) and white/black (-) - mentioned by Harper7 for 2003. LINK
I have a 2010 SR5 with the rearview monitor built into the rearview mirror. It has a connector with (7) wires in a connector with 2 rows of 7 holes (see picture). Does anyone have a diagram indicating the proper 2 wires to get ignition switched power before I go cutting into the wires and mess something up? The wires are like 22 gauge and the connector is too tight to get my volt meter points into it.
bottom row - from left - blue with green dot - black &white - red - empty - empty - black - white
top row - from left - empty - empty - empty - empty - empty - orange - red
Any help would be appreciated
The download links are in nashman's thread, which should really be made a sticky (hint to the moderators), and will provide a complete diagram. I think it's either at the bottom of page one or maybe page two. Either way, if it helps you out, tell him thank$ :hatsoff:
According to the wiring diagram pg 100
Blue is Pos and white/black is Neg
You really should double check with a voltmeter though.
That green dot is probably the inspecters mark showing it was checked??
Camera connections are on page 353 of WD's
Looks like they are calling the orange wire brown?
Tip....Use needles or small paper clips cut down to check voltages on a plug with holes too small to get your voltmeter ends in.
I just have some old sewing needles that I dulled the point on in my electronics toolbox to use to pin connectors out.
Here is the first page of the mirror's electrical prints. I'm guessing "L" means "blue wire".
So the blue wire is power, the white black is ground.
The adjacent Blue (positive) and White/Black (negative) wires on the bottom left of the pictures above are the correct 2 wires for switched 12v power for this mirror set-up. I would like to thank Ryan for digging up the diagram, Ryan - And also thank Mike. I especially want to thank Harper7 for just being a great member of this forum and always trying to help when he can.
I will post a follow-up tomorrow after I test and try to tie-into the wires.
