Needed: Info on replacing OEM suspension
SoCal C4S
I recently bought a 3rd gen T4R with 217k miles. The suspension feels very loose and I'd like to replace most of the (or entire) suspension, so that I know what I have versus having no idea.
Probably do a leveling lit or a small lift too.
Thoughts, links, etc. would be appreciated.
Toytec complete kits. 3 or 4 options. I went with $750 option.
Sent from my SM-G920P using Tapatalk
Your best bet is to hit this link:
http://www.toyota-4runner.org/3rd-g...faq-tutorials-documentation-reference-v2.html
And this one for the lift:
http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.html
There's a ton of information on this site, and many of the best threads are cataloged in the stickies at the top of the main page.
Once you've taken some of that in, you'll be able to ask the right questions.
On a truck with that many miles, the first thing you want to tackle will be the lower ball joints. They're a well known problem, and the failure mode is basically the front wheel falling off. It could be catastrophic in certain situations (80MPH on the interstate for example). There are plenty of good write ups in that link.
While you're doing that, it makes good sense to do the inner and outer tie rods at the same time. That saves you the trouble of breaking the tie rod loose from the ball joint, and it's only another $100-150 or so in parts.
Once you have those things taken care of you can be confident you're safe, and then move on to things like steering rack bushings, shocks and struts, and sway bar end links.
The other major thing you want to take care of is the radiator. The failure mode on these allows coolant to mix with transmission fluid, and creates what's commonly called "the pink milkshake". It almost always ruins the transmission. The radiator is about $100 (and easy) to replace. The transmission.....not so much. :thumb:
I would recommend the 99 coil and springs. Gives about 1" lift and rides very smooth, since it's OEM from Toyota.
Even if you replaced it with stock parts for your year, it'll regain lost suspension height due to wear over the years. That's what happened with mine. It was pretty saggy in the back.
seltzernator
