Negative battery terminal change
jonb2
Member
Hello, looking to change out the oem negative battery terminal and convert to a mil-spec or marine type terminal. The positive terminal can be separated from the positive cable, but the negative terminal and cable are a single unit at the battery.
Has anyone done such a repair or swap on the negative terminal? Appreciate any ideas.
thanks!
Not hard. I have milspec terminals.
Just cut and crimp on new battery terminals and you're good to go. Make sure you have a proper crimping or soldering tool.
delislerebecca
