Elan750
Boot? You must be referring to our timberland sponsorship. They sponsored us with timberland tires, but not a single pair of boots. Lol
I meant the one that saved you from the fall
I meant the one that saved you from the fallI thought you might have it on display or something
Any sneak peaks at the Tundra?
What I have gotten done is the LED interior/exterior lighting.
One of the most important bulbs for me is the Backup bulbs (Part Number 7440). Not an easy sway in the GX, so let me make a suggestion or three.
1) you do want to replace these often because they are hard to get to.
2) don't buy the cheapest bulb you can find just because it says it has a million lumen.
3) Cree and Epistar are both good options, but make sure they are legit (not knockoffs) and make sure they are the ones with the built in aluminum heat sinks.
this is what I am using.
The running board lights, rear dome, cargo area and courtesy lights are all 194 bulbs. As a personal preference I use CAN Bus bulbs because there is more contact other than just a little wire on each pole. IMHO, the CAN Bus bulbs are a more reliable bulb and not as finicky.
Here are the bulbs I used.
Lastly are the map light bulbs (part number BA9S) these bulbs are a throw back to the old chrome Phillips 2C flashlights. they are a push and twist mini globe bulb. There are not a lot of option for this style bulb. So just pick a true Cree or Epistar bulb and hope for the best.
Hi,
May I ask for the brand and where you bought the three bulbs below?
Thanks!
Nathan: I like that Build Wall. Good to see Gary's Ruger Runner up there on display. Hope all is well up north.
Cole
So...It looks as if I still have a thing or two left on this GX, I ordered a Gibson SS Exhaust from [MENTION=9]Jason B[/MENTION]. I unpacked everything today and will install tomorrow. It looks pretty straight forward aside from one thing. The 2 bolt flange; not sure if it need a gasket/donut or not. There is not one in the kit, so I assume no.
Stay Tuned for an AAR
Where did you buy the fender liners?So..... I decided to do some maintenance on the GX and at the same time do some upgrades.
I had a wheel bearing with a TINY amount of movement on the pass side, I noticed it when I had it on the lift rotating tires. Then I noticed my upper control arm bushing was torn. So I did what any reasonable person would do...
I ordered new bushings for the tube upper arms, E-coated rotors, Wagner calipers, energy lower bushings, timken wheel bearings, moog greaseable cam bolts and inner/ outer tie rods. I figured if I'm doing bearings, I might as well do everything. I topped it off with some RAD fender liners.
Sent from my SM-G900P using Tapatalk
Great write-up and install! I appreciate it.
I'm extending the Black Friday sale for this exhaust. It's a killer deal:
GX470 Gibson Catback at Burtman Industries
