New 5th Gen Roof Rack Now Available (Full & Standard Length) | Victory 4x4
Victory 4x4
Official Vendor
4RUNNER ROOF RACK | 5TH GEN (10+)
This roof rack system allows for mounting almost anything, freeing up valuable cargo space for other trip essentials. Comes coated with a 2 stage satin textured black powder coat over durable zinc primer finish.
  • CNC cut and formed from 3/16" aluminum (steel mounting brackets) with extruded aluminum rails
  • Easy bolt together installation
  • No drilling required
  • Available with or without 40" lightbar cutout (on the full-length rack)
  • Milled T-nut access points
  • Fairing Edge Trim Included
  • Powdercoated
  • Hardware Included
  • Made in the USA
  • Free shipping!
Install Video
Standard Length Roof Rack Coming Soon!(Factory Rail Length)
Forum Members, use coupon code RACKCITY for 5% off!
Lead times 10-15 Days!
Very nice! Compatible with a ladder? Looks like it sits very close to the channel where ladders usually mount to
Is that a typo on the website, or does it really only weigh 36 lbs? The Prinsu rack is listed at 85lbs and it's made of aluminum too.
Looks damn nice, but regarding the lower weight, perhaps the cross bars aren't as sturdy? The LFD Off Road cross bars at least look more sturdy, not sure if they are or not.
36lbs is correct including the steel mounting brackets, plus or minus the hardware and lightbar brackets if you get them. Maybe their weight is incorrect?
What the load bearing weight on the rack?
Any issues with wind noise on that front fairing.
The only weight number Toyota seems to give are for the stock rack crossbars (not side rails) which are only rated to 132lbs, our rack will support a lot more than that, but it is up to your discretion. I ran a Freespirit rooftop tent, myself, and sleeping gear on our crossbars without any issues.
I have not yet driven on the highway but up to about 55 mph there doesn't seem to be much added wind noise.
Prinsu's side rails are 1/4 inch where Victory's are 3/16th. I don't think that small of a different would make that much of a weight difference.
Does anyone have any notes on how much the Prinsu actually weighs?
Do you have any pictures of the lightbar cutout?
I do not have one installed on the 4Runner yet, but it will be about the same as the Tacoma Rack.
Great timing, I was about to place on order for a different rack, but I think I like this better. These photos look great, but the edge trim in the install video looks sloppy not going all the way across. Is it required in the rear- does the rear fairing make contact with the body? Have you tested road noise without it in the front?
