New Battery
madeinhb
Member
So I replaced my 2006 battrry with an Everstart Maxx 24F from Walmart. This is the battery online said to use. But now my auto window and sunroof won't open using the auto feature. Only works if button is held down. Is this the right battery orbit something else going on?
Anytime you disconnect your battery you'll need to basically "re-teach" these functions. All you have to do is open your window all the way by holding the switch. Once it's all the way open, then close it all the way by again holding the switch. This will effectively teach it where to stop for each cycle and the auto-open/close should work again. Same holds true for your rear window and your sunroof, if you've got one.
I will try this on my break.
2001ATL
