New Falken AT tire (A/T3W)
As you go up in load range for a given tire size, the tire is designed to handle more weight. So there is more material (rubber, steel, etc) used in making the tire to handle more weight. Since there is more material used in constructing the tire, they are heavier.
To piggy back off this, the Standard load range is what majority consumers purchase? The only reason why someone would want "E", is for more tread and haul heavier loads?
Or for puncture resistance if mainly rock crawling.
Or you have no choice cause it's the only rating available for your size. (I wanted to run a 255/80r17 and it is only available in an E rating.)
i bought my 16 SR5 last July with brand new General Grabber HTS60's, which were a nice highway tire, very quiet. i wanted to upgrade to an AT tire and after hemming and hawing, i was ultimately swayed to the Wildpeak by a friend who loved them on his Taco.
as many have mentioned ITT, discount tire price matched Walmart ($127), and had them road force balanced and installed in like 15 minutes. immediately went on the highway with them and it was total butter. i could not believe how quiet / vibrationless (?) they felt. i've got about 1k on them so far and couldn't be happier. i set them at 35psi on road / 20psi off road.
i can't speak to mileage difference, as my driving is kind of random.
I just wanted to add as a data point for those interested: I looked up the DOT code, and my tires were fabricated in the Buffalo NY plant. Still going strong with no vibration whatsoever at any speed.
LOL I'm sorry, yes I meant why Load C (6 plies) weigh more than Load E (10 plies)!
I picked up a set of 285/70/17 C loads from a gladiator bro. Coming form the same size but Load E Toyos AT2's, I can tell you these Falkens are considerably heavier and require noticeably more braking force than the Toyos. I'm not sure how I feel about the Cs at this point and probably wouldn't recommend them.
Stepped up from BFG KO2 E load 275's to AT3W 285's in SL
Just when you thought this behemoth of a thread was gone, I brought it back.
Last Saturday I bought new SL AT3W 285/70-17's to replace my BFG KO2 275/70-17 E load tires. My Pro had no modifications at all prior to the 285's except 1.5/1" Cornfed Pro spacers. No mods required either for the 285's with no clearance issues at slight to moderate articulation. Impressions: AT3W's make more noise than the KO2's. Not much and not annoying. The 10 ply KO2's cornered a bit better, and had a tad less nose dive. AT3W's ride a tad smoother and absorb bumps a little better than the 275's. I think the KO2's have a slightly more aggressive tread look, but, the AT3W's are a great looking tire. Matter of personal opinion. I like them both. I have had KO2's before, both in E loads, and I think they are super tough and have never had a flat with either set. Although, I only had 13k on the 275's, but, 55k on my 2001 T4R. Uphill grades have a slightly longer shift point, of course, but, not that bad at all. Overall I am happy with them so far. I went this route for a little smoother ride, the larger tire/looks and the price.
So what is the general consensus of PSI people are airing down for desert and rocky environments on the SL rated tires? I know the recommendations MAST4R has given based on his anecdotal experience which has some really good insight, but after scouring tacoma/jeep and various other forums I still see a majority of people running between 16-25psi. I mostly run trails in Socal and have tried 25-30 PSI and still feel unsure of what PSI I should be targeting for good traction without compromising the softer load of the SL's.
Im using lt tires so cant help you there. However, i will say that try not to get hung up on what everyone else is running. If it works and you got up the trail, then go from there. From what i can recall, the sl and lt wildpeak have the same sidewalls so you should be ok.
LT275/70/17, what PSI do you air down too on moderate trails?
Is 20 good enough? 41 PSI is recommended for street use.
Thanks in advance.
Thanks in advance.
25 is good for moderate trails. I would not go lower than 15psi. 15 for rocks and tough trails. I’m talking about an E load.
With all the negative reviews lately, I want to share my experience as it’s been EXTREMELY positive.
* Discount Tire price matched Walmart.
* Tires were delivered within 24 hours.
* Toyota Dealership mounted/balanced. The tech said it was one of the easiest ATs he’s ever balanced - said it took much less than the BFG KO2.
* These tires ride great on and Offroad.
Below are the specs if someone is data collecting:
265/70/R17 115T
Build date: 0720
Made in Thailand
I’ve ran Toyos, BFGs, Coopers, Nittos, etc. and these are by far my favorite ATs.
Got the same tires delivered today - not installed yet - but mine are Made in USA.
Looks like they moved production to the US.
Oh and build date is 09/20 for one tire and 21/20 for the other three.
Thanks for the info - please keep us updated after you get them mounted and some miles on them.
Mine are still doing great. Bit more road noise than the OEM tires on the highway, but to be expected considering the additional tread depth.
I was hoping my last set was made in USA. But no good. All 3 sets I had all had same issue. My tire place installs a lot of the Falkens with no issues at all. I had no luck with them.
How do you know they are US made or not? are they stamped? I haven't paid much attention.
