New Member in need of some HELP (3rd GEN 4Runner)
So I found some flares on craigslist but before I pull the trigger I have a few more questions guys. Will I need to drill holes to install these? Also I have the Millennium Silver model, I'm wondering how the color of the flares will look on my truck. Please see the link below for the add:
96- 02 toyota 4runner vidrios puertas
Let me know as I'm sure these will go pretty fast. The guy says theres 9 pieces but doesn't speak English too well. He's asking $300 [MENTION=9596]paddlenbike[/MENTION]
Something to consider with the "SR5 Wides" is that the sheet metal is drilled in order for the flares to be anchored on. This is not the case with the "skinny blacks" I believe.
Also, with the black flares, I think there are OEM front mud flaps available since you don't like the unfinished look (don't blame you) when the step rails are removed.
Firstly there are four different flares that came on the third gen
Limited Flares: Came on limited's 1996-2002
These always came with the side cladding, and its built into the door part of the rear flare. I think the mudflap of the rear flare is different than the sport flares. Also these always had the running boards. They mount using clips that fit into holes that are on the body. not exactly sure but from 1996-1999 these only came in two colors, silver and dark grey (maybe black), from 2000-2002 they came in various colors
SR5 Skinny Black: Came on SR5, always on 99 highlander 1996-2000
Other than the Highlanders these were a dealer only add on. When these didnt come with running boards they had a special front mudflap thats really rare and sought after. They mount using holes in the fender lip the same as the chrome strips.
SR5 Wide/ Sport: 2000-2002 SR5 and always on the Sport Edition
These are just like the Limited flares but have a different rear mudflap and there is no cladding on the doors.
Skinny Chrome: 1996-2002 sr5 and base.
i dont think there are mud flaps available for the limited or sport flares, and I had to drill holes under the lip of the fender well for my skinny black flares, but mine came with no flares at all not even the chrome strips.
Honestly I dont think anyone has ever put the wide sr5 flares on a 4runner that didnt come with one. First you will need to drill some square holes for them, and in a pretty accurate pattern, could be quite the project. if you do this, id try to make some templates based on someone elses that came with them, they would have to remove them so you could get the pattern, and i think the clips usually break when they are removed, so unless youve got a good friend with a 4runner i dont think anyone will let you take their flares off and see what it looks like. you might be able to figure out the pattern just using the flare but it would be a lot easier to use a big piece of paper on the body of the truck and mark the holes.
Anyways good luck with the flares.
Good call on the differences between the Limited Flares and SR5 Wide Flares! I remember reading a thread where someone installed the SR5 Wides on their 4runner and tried to find it for the OP, but could not (someone mentioned the member [MENTION=24484]blackstar[/MENTION] did it, but could not find any threads by that member). It was a very involved process as I recall.
If they OP is committed to that work though, make sure you get the flares that are for the SR5 Sport and not the Limited.
Yeah it does. Mine is just like the top. I am looking for one of the latter two, although the bottom SR5 wide would be ideal. The skinnys would work but seems incomplete without running boards and I dont really want to put those back on. Really hoping something will come up, the chrome strips are bugging me more and more each day haha
Also, if I get a toytech 2.5/3" lift, will 265/75s look too wimpy? I use mine as a daily driver and an occasional off road trip. Mostly just camping up in the mountains and some trails. Just from what I have seen 285s look cool but will decrease power, gas mileage, and will need some trimming to work.
Thanks again guys! Helping a new 4Runner guy out
I have this exact lift on my rig, the 265s did look a little small IMO.
Here it is the weekend that I finished the lift: Imgur
I ended up going to the 285s a couple months ago, and just like you said I've lost a little top end power and some mpgs and I did have to do some trimming. But I was aware of that when I chose the tires. I am very happy with the way they look and preform. NEw Wrangler Duratracs - Album on Imgur
Enjoy your new Runner and happy wheeling!
Thanks for all the input guys
So I decided Im not going to go the route of getting limited or OEM SR5 wide flares as I dont think drilling that many holes is ideal. Plus from what I have seen, those flares go for $300 plus and thats once you find them. You will also have to paint them to match your rig, if they arent already the same color which will be more money. I have found a few builds with guys who went the bushwacker extend-a-flare route. They look pretty much spot on in comparison with the sport wide SR5 flares once painted to match. Or you can just leave them black (like the skinny SR5 flare). Personally, I will paint them as from what I have seen they look much better. From what I have gathered, the Bushwackers will not need all the holes drilled and will work with what I have once I remove the chrome trim.
Here's a link as reference for how bushwackers painted the same color would look:
http://www.toyota-4runner.org/3rd-gen-t4rs/89603-bushwacker-fender-flares-project.html
