Weird, I thought I posted an update on here a few days ago. Oh well, anyway I did pull the old motor and it was fairly straight forward. If you can turn motor over by hand ( I couldn't, mine was seized) you can get to the flywheel bolts which will free you motor from your trans. Pull the inspection plate and they're right there, 10mm if I remember right. Since mine was seized I had to bring the torque converter out with the motor and unfortunately lost a lot of trans fluid etc. and also had to pull my fan off the front of the motor to make room for the torque converter to clear.
To answer the other question, yes, the motor is mainly Toyota parts with a few exceptions from my understanding. Everything seems to fit stock and look stock.
A few problems I've ran into so far:
1. The water bypass pipe has an o-ring. The dealership can't find the part and says it doesn't exist. I've been in 3 times and they can't find it. I used my old gasket and also a TON of RTV to hopefully not have it leak. If it does leak I guess I'll be pulling the manifold again.
2. Broken bolt in the manifold. Not sure why but it happened. Was using my torque wrench but for whatever reason the one bolt snapped.
3. Broken clips for knock sensor sub-harness. They get very brittle because of how hot it gets right on top of the block and under the intake. Not a huge deal, a new one from the dealership is $25.
So far that's really about it. Smooth sailing but it hasn't gone in and been started yet.
Here's a few pictures:
Knock sensor harness
Fresh Radiator
Pretty much assembled
Coil packs and TB on
Broken Bolt in there
Oil Cooler on
Hope I can get it in tomorrow night. Trying to get a few extra hands to help me ease it in.
