03_4x4Runner
Senior Member
I read about these in the new 4WD Toyota owners magazine. They do not mount to the frame like most sliders. Toyota 4Runner Rockers
will not rattle bang or flex like frame mounted rock sliders
The slider basically has to flex up until it hits the body when you jack or land on a rock. The body is supporting the wight (sic) OR the tube slider will continue to flex up 1-2 inches or more if the body is not there to stop it. This means the tube slider needs to be mounted over an inch below the lowest part of the body to keep from hitting the body.
Sounds nice.. a little put off by what appears to be a rivet installation.
But I worry about how well they hold up against serious abuse in terms of mounting against the body, vs. frame mounted ones. Their complaint is that the frame is thin, the sheetmetal on the body is even thinner.
I run sliders on my FJ and have definitely used them hard. To claim they flex up to two inches or can touch the body etc is insane. I have had the complete weight of my FJ on my sliders. They do not bang or make noise. I do not lose ground clearance. I agree with KidV.
Hence, due to their ridiculous marketing statements, I am highly skeptical of their product.
Cheers, Steve
Re: not losing ground clearance; sure you are, specifically the diameter of the tubing used in whatever slider you have on your FJ. The question of whether or not the reduction in clearance at the rocker matters in the situations you wheel in remains though.
As for a body mounted slider, I've had them function excellently for years on a rig that's been beat on much harder than any 5th gen I've seen.
As noted, the potential for corrosion is the reason I wouldn't install a set of these on my Runner.
I'm confused. The lowest point in my 4runner is my rear diff and/ gas tank... I don't think sliders hang lower than that.
If you lifted the 4runner up with just these sliders the entire frame and drive train would be hanging from only the body mounts. This seems like a lot of undue stress on the body mounts and body to me but then again I am not a Toyota engineer. Any one else care to chime in on this?
