New tires and TPMS
mrrab
Quick question...I have a facility available to me that allows me to mount and balance my own tires with the assistance of someone knowledgeable about the tire mounting and balancing machine.
Now, I think I need to be careful when taking off the old tire and installing the new tire because of the TPMS system, which by the way I've disabled.
Do I need to do anything with these valves when replacing a tire? It's not like a wheel in which you just install new valves...
Thanks,
Alex
On second thought...If I disabled the system could I just removed the TPMS sensor and put normal valves in there. I don't see why not...
TPMS...Dumbest system ever. Designed for general population that doesn't know how to check their tire pressure.
True but is has saved my wife and I a couple times when the tires were punctured while driving on the freeway before there were tell-tale signs behind the steering wheel.
^ ditto for me . Bit of a hassle but it does the job & I mean does that little bitey light really bother us THAT much ? Piece of my powdercoat came loose between tire & wheel started loosing air slow , and you know sometimes you don't do a walk around to check well TPMS saved me some hassle .
Yup, saved me too. :iagree:
Not sure why someone would fix something that ain't broke, but as always, YMMV.
Daren
