New tires
95_Dusty
Okay guy and girls,
My truck is setting on the stock size tires 31X10.5 R15 and I want to get a full set of BF Goodrich Baja AT that are 33X10.5 R15. Can i run this without any mod to my truck and if so which mods would i need to do? I do have a hock up at American and Discount Tire Im looking at only $930 for the set.
Youll probably have to hammer the pinch weld in the front fender. But they should fit fine, I like the tall skinny look.
Haha. Thanks Nate. I was confused because he said baja AT not TA. Just making sure hes not paying 900 bones for some normal BFG ATs.
33x10.50s will fit just fine, I have them on mine.
$930 for 4 Baja T/As is a steal, on the other hand $930 for regular A/Ts is not a bad deal as long as they are mounted, balanced and roadside for that price.
dont forget if you get 33s you will want to re gear before you cause damage to your driveline and have a super slow truck.
so to run 33s youll need at least the 2.5 lift with add a leaf and 4.88 gears
so 500$ or so extra just to run that size tire.
Stick with 31's until you have the money saved up for a nice lift and gears then you could run 33s or even 35's
I dunno I have heard of people running 33's stock no problem. In fact one of my good buddies had 33"s for a while before regearing and he only had issues on the highway the regear was just to help out there for him. For someone like me that drives a mile a day to work and the most highway driving I do is to the trails it shouldn't be an issue I wouldn't think
it does have a lot to do with the use of the vehicle, but it will put unwanted stress on the engine and other driveline components.
TerryNap61
