New to me 4runner temp gauge fluctuating
Yea. You can tell it is the fan if it overheats at a stop but is solid on the freeway. Fan doesn't do anything at 60 mph....
Ok, sorry If I cause confusion here but I am new to message boards and do not know how to begin, nor can I locate a tutorial so, here goes.
Similar to the above post, I also have had an erratic gauge reading. When connected to a Bluetooth to phone scanner (OBDLinkMX) I can monitor the engine ECM reported temperature at 210. The gauge, however; moves up like normal(ish). After what was long distances and now only short distances, it climbs toward the red and beyond. If I shut it down and wait, the gauge will fall back into the normal zone, quickly. Since the scanner can read both it tracked the gauge going from 240 (apparently max) to 200 in about thirty minutes while tracking the ECM sender to have gone down maybe three degrees. Since physics basically prohibits the engine to drop that fast, when shut off an not under water or in antarctica (I am in central Florida) I am assuming that the sender for the gauge is defective. Now, I have trawled this forum and downloaded the various service manuals on offer as well as reading posts in regards to 4thgen 4.0L and I can not find anything specific to this. Nor can I find, in any of the books or online, where the bloody sender is located. I have purchased a new one and every search points to the engine ECM, which I have found on the engine and will replace once I find this little bugger. Does anyone have any idea where this sender may be located? For reference, I purchase both a Napa TS6677 and TS6678. The TS6677 is for the ECM and again, can see it. The TS6678 is, who knows. Anyone else have this problem or think I am barking up the wrong tree?
Model 2004 4Runner Driver Type 4WD - Grade SR5 Transmission - 4AT - 4 SP 4X4 A340F Transmission - Engine 6-CYL Date of First Use July 23, 2004
wayblom
