New to T4R - 2019 'TRD Faux' in Super White
BimmerBen
bimmerben-albums-2019-trd-off-road-premium-picture58557-ca1afa2b-2c5d-4b59-8ba7-ce653bafb5ba.jpeg
bimmerben-albums-2019-trd-off-road-premium-picture58556-f63c2930-4a01-40b8-a906-95eccf9fe8ba.jpeg
bimmerben-albums-2019-trd-off-road-premium-picture58555-5245bbce-33fc-41a4-b84f-a8aa88185d0c.jpeg
bimmerben-albums-2019-trd-off-road-premium-picture58554-dd24f839-3a5a-4d6a-89f2-934f7cae8a22.jpeg
2019 TRD Off Road Premium
-(4x) Baja Designs S1 mounted behind grill, wired to OE-style button and using Trigger ONE bluetooth relay to allow for dimming. Can be used as 'raptor lights' when dimmed, but quite bright when fully powered.
-Baja Designs S1 Mounted inside tow hitch and wired to 7-pin trailer plug to be triggered when in reverse.
-TRD Pro skid plate
-(2x) Warn Epic shackles
-Cartrimhome TRD Pro grill valance wrapped in gloss black vinyl
-Wrapped front and rear lower valances in gloss black vinyl
-Wrapped wheel center caps in gloss black
-Morimoto 2stroke low beams
-Morimoto projector led fog lights
-PIAA yellow halogen high beam/DRL bulbs
-Kempter Kustoms 'ironman' style TRD side badges and black replacement "off road" and "4runner" badges
-DEPO black tail lights
-Cartrimhome flip key, wrapped in gloss white to match Super White.
Wheels and tires are next. Leaning toward 17x8.5 SCS F5s in black with 275/70/17 BFG KO2s. If anyone has experience with this setup on stock TRDOR suspension, I'd love to hear.
Love the key fob. Where did you get it? Got a link?
Free Shipping Toyota Modified Flip Folding Remote Blank Key Shell - must have G-Key For 4runner 2010-2020
Mine is the "A-Style". Swapping the transponder is the most difficult part of the mod. It is glued in to the factory fob and I had to use a heat gun and xacto knife to soften/cut away the glue, then a very small flathead to pry it out. Had the key cut at a local hardware store, but they were uncertain if it would work. Original key will not be destroyed if you take your time, but you will have to re-glue the transponder if you wish to swap back.
-TRD Pro skid plate
Sweet key fob!
