No 4Lo light on startup
03V84R
2003 Sr5 V 8. I believe the 4Lo light would come on upon starting the truck ,like all the other systems lights check on startup. I tried using my 4Lo and noticed this issue. The light dosent come on when the car is started and nothing happens when I turn the dial?
I recently had the dealer reflash the ECU for a recall. Also had the brake accumulator and ABS pump swapped out. Not sure if it's related?
I couldn't find any blown fuses either.
Any help would be appreciated.
I forgot to check this on mine because my dealer reflashed my ECU last week, but I just went out right now and confirmed everything is functioning as it should. My 4LO light does not come on at startup, but it does come on when I move the vehicle into 4LO. I would assume the problem is elsewhere and not related to the ECU flash
Does your 4Lo work? Im confused.
DionicioLives
