No lights
Chris98t4r
Hey guys need some help here. The lights in my climate control unit don’t work as well as the clock and the light around the ignition key. Both dome and acc fuses are fine. Are these common failures or am I missing another circuit feeding these items. Any thoughts are appreciated
A wiring schematic would probably help you out a lot. Especially if you find the lights in question are on the same circuit or branch circuit. Could be nothing more than a loose wire. Good luck.
AndiGarage
