No more fog light ?? d
Emman
Last night when I started my 4runner I realized that my two fog light was not working.
I have ddm tuning on low beam and fog light and the low beam still working ..
Today I tried installing the stock fog light 9006 but still nothing ???
what's the problem ??
I don't know
in the fuse box under the hood does it have a spare fuse for fog light ??
how many amp ?
in the box cover it's FR FOG ? that's it ?
with hid fog light can upgrade to 20 amp or more ? what is the best ?
FR Fog is the factory fog light fuse. Look at the inside cover of the fuse box and there's a diagram. It should be a blue fuse with 15 on it. If you are converting from halogen to HID than the HID may require a different fuse (type/amp/or both).
I recently replaced my fog lights with PIAA 510 and used the factory wiring. The PIAA required a 20 amp regular fuse, so I just tried replacing the factory 15 amp mini with a 20 amp mini, and the fuse would blow every time I turned the fog lights on. I ended up using the PIAA wiring kit that came with the lights. The kit also came with its own 20 amp regular fuse.
I'm no electrician, so I can''t tell you whats best. I can only tell you what I have experienced.
Sorry I cant be more help.
ddm tuning have wiring kit but I don't know if the kit have a fuse 20 amp ..
Laredotx
