No music, no time, no power
t4r4life
Elite Member
i bought a air compressor from ross the other day i pluged it in and it doesnt work after that i take it out the radio and clock and cig socket doesnt work did the air compressor short out the fuse?
More than likely. Check it. How many amps does the compressor pull? Accessories like that normally come with battery cables too, I'd use those instead. Whatever you do, DO NOT try to use a bigger fuse to accommodate the compressor. That's just asking to burn your rig to the ground.
i returned the compressor it was one of those small ones that plugs into the 12v socket, didn't even work. which fuse would likely cause to that?
this is horrible because i have to keep checking my phone while driving which is not safe, i got no power to charge my phone or gps, and i got no music which means i gotta sing to entertain myself and my singing sucks donkey @SS, HELP PEOPLE!!!
here's a pic since I already took it anyway
You've got a fuse panel on the left side of your dash in front of your left knee. Check to see which one says 'ACC'. That's the radio. 15A
man that sure was the one burned to the root, when to toyota and got the fuse everything works now, nowi can listen to my lady gaga in peace. jk only rock metal blues hiphop rap techno allowed in my car.
Glad you found it, go to Wally world or Autozone and get you a little plastic box of replacement auto fuses and keep them in the glovebox for "next time".
