No power to fog harness?
jayhat
Swapped my working Baja designs fog kit over to my taco. Removed the Baja harnesses, installed the factory light housings, reconnected factory harness to the bulbs, and nothing...
- checked the fuse in cabin fuse box. It looked good but I swapped with a spare just in case.
- headlights are on and fog light switch it on.
- tested by sticking DMM leads into the harness and I’m not getting anything.
Any ideas?
I’m an idiot. I pulled out several things last week including a couple “add a circuit” fuse adapters. One of those was tapped into the 10a tail light circuit. I didn’t check or know because it was daylight earlier but the taillights were also not working. The fogs require the taillight circuit to work. Once I threw a 10a back in there, I was all set.
Ambrose67
