Noises
Hyaline
Had a bad right wheel bearing and was hearing the regular wheel bearing symptoms. Ordered a new one,, Now I got another sound and its driving me crazy. I replaced the wheel bearing, moved the tires around and still noise is in the front right side. Any suggestions? Replaced the left wheel bearing last year if i recall correctly. [MENTION=66389]BlackWorksInc[/MENTION] I know you just did your bearings. Did you clean all the grease out of the seals when you replaced them? I had some grease and I thought it needed to be there so I left it. Ill take pics as soon as I can.
Possible brake noise? My first thought. Or 100 perfect sure it's from wheel bearing. Don't know what the douse sounds like.
The sound is only at low speeds sub 35. Its like vibration and a rubbing sound every 5-8 secs. Ill try to grab a sound byte if I can't get it straightened out by tonight.
After I replaced my last wheel bearing a frozen caliper manifested.
Jhunt
