noob question??
ezekiel86
im probably going to buy a 2000 4runner tomm and i was wondering how the 4wd system is, from what ive read they are 2wd and when you lock in 4wd it turns it into a awd setup unless you have the rear diff lock? am i correct in this assumption? thanks for any help(edit) it has the etc button so does that mean it has the rear locker? im new to this sorry,,,
no.....
a diff lock has nothing to do with 4wd essentially at least for just getting around
when it's in 2wd the rear wheels are the ones the engine sends power to,
when you put it into 4wd it should lock the front to the back sending power to all of the wheels, depending on what 4wd system you have it does this in different ways on some 4wd systems it truly locks the front to the rear and this is great for off road but causes binding issues when on the street, some 4wd's act like a awd and have no binding issues these tend to be less desirable for off road as the power separation is never truly 50/50 instead it sends power to various wheels and can cause problems when slipping. personally i'm not a big fan of the awd like systems and prefer a true mech lock for front to back, the '99 multi-mode t-case also in some '00's have awd,true 4x4 and 2wd so essentially you have all of the possible options, look for a push button on the side of the shifter to see if has that, i think it only came on limited models though.
a diff lock locks the wheels from left to right as opposed to front and back like your t-case does.
even in 4wd if a wheel comes off the ground you can get stuck as the truck will transfer power to the wheel that is slipping and if the tire is in the air the truck this it's slipping more then the others so you get no power to the wheel that has traction, when you use a diff lock (front and rear only center diff lock is fake, it's basically just plain 4wd) it will lock both tires left and right together and the tire with the traction will now recive 50% of the power going to that axle.
this can get very very confusing as brand names and manufacture come in to play, technically awd is a subaru thing and other car manufactures call it by various names and you can even achieve the same basic ideas through a myriad of different parts/mechanics that all achieve the same basic thing.
i break it down like this
2wd
awd
4wd
and then the hi-lo variations of each and then "locked" variations of those.
sorry, its the sr5 with the 3.4 and the sport package because it has the hood scoop and fogs and its not a limited,, thanks
sport edition with add/vsc unless the hood scoop was added aftermarket.
does it have the sport edition badges on it and what color?
its silver and the hhod scoop is factory, it only has 99k on it and im getting it for 9,400$ so im pretty happy with price and all that but was wanting to make sure the 4wd setup it has is a good one, thanks for the replies,,,,,,, and no on the sport edition badges, at least i dont remember them when i test drove
There was no "sport edition" in 2000. In 99 and 00 they were an SR5 with a certain "sport package" option package and an internal designation called "Highlander". "Sport Editions" didn't formally come out until 2001. That's why you won't see any special badging on it.
2000 SR5s will only have a traditional 4WD system with a possible option for an electric locking differential, like mine.
sticker.jpg~original
ok good, i dont remember anything by the shifter but ill find out tomm, where would the buttton be for the locking diff? thanks for the help
It will be a button with orange lettering that looks like this, on the left side of the dash.
Says:
RR
Diff
Lock
If this switch is not there, there is no rear diff lock.
to put it easy, the 4wd drive system is phenomenal! I rarely use my center locker and i can pretty much get anywhere i want. I have driven tons of other trucks and SUVs ( i used to run a rental car branch plus before that I sold cars for a bit) So i've got to test a lot of the trucks out in the snow, Even in 4wd i was slipping all over the place in a lot of those suvs.
I love the sytem in the 4runner! it amazes me every winter and every time im out wheelin
ezekiel, Just so you know, your truck doesn't have a center locker.
You are either in 2WD, 4WD or neutral. You can only lock your rear differential in 4Lo unless you mod the wire harness (search for blue-wire mod) and then you can lock it in any mode.
Full time 4WD with a locked rear is plenty capable.
you should mention that configuration has no AWD style mode, meaning he should only engage the 4wd on fully snow covered roads a such i.e. places where the wheels can slip.
meaning if your driving on a curve road that has spots of ice and then spots of clear pavement you shouldn't use it as it may cause binding issues.
is that right guys? i'm not an expert on model levels.
1d8618ec.jpg~original
thanks guys for all the info, i just picked her up yesterday and love it, came up a really steep road and the check engine light came on for a little while and ended up going off so im thinking i have a loose sensor wire or something, the 4wd works amazing, drove up every steep field i own and didnt slip at all, thanks for the help
Nice. Looks like you got the Black Pearl emblems too. Sweet.
Get yourself a code scanner. Everybody should own one. You computer may still have the codes stored even though the light went out. If it is intermittent, you will want to scan it quickly, so keep the scanner in the truck.
I got mine off Amazon for a pinch over $20.
Amazon.com: Autel MaxiScan MS300 CAN OBD-II Scan Tool: Automotive: Reviews, Prices & more
You want to know what that code is right away, in case the seller is trying to pull a fast one on you. Did you buy private sale or dealer?
albertpeter156
