Noob Questions
bhicks
Member
Little info about myself before I get to my questions. Name is Brad. I owned a 91 4Runner back in the mid 90's. Put a 4" Lift and 33's on it with some custom tube bumpers and had fun with it all through college. Eventually the IFS front end got old so I sold it for a built 93 SR5 4Runner on 35's with the Solid Axle conversion. The axle was from a 93 FJ80. I wheeled that all over the SoCal mtns and desert and loved it. Eventually I got married and kids started rolling in so I picked up a 95 FJ80 (with 3rd row) to replace the smaller 4Runner. Lifted and built it and used it for my trail rig for a few years. Eventually I wanted something newer so I picked up a 97 Lexus LX450. I put a 4" lift, sliders, bumpers and 35's (37's on the way) and have been wheelin it up until now. There is also a pile of Jeeps mixed in their over the years but I wont go there since this is a yota crowd. I love my toyotas and I love to beat on them. During my last wheelin trip I came across a guy on the trail with a 2010 4Runner trail edition on 35's. Not sure the height of the lift or how much had been done to get it to that point. He had a factory rear locker and some type of factory limited slip up front. It handled well on the rocks considering it had the IFS up front. After my cousin (who was sitting shot gun) saw it perform he decided he wanted one just like it. I may pick one up as well. here's where the questions begin. Feel free to try to answer one or two or all of them.
What packages offer a rear locker?
Do any packeges offer front and rear lockers? If not, what's the next best thing for the front from the factory?
Who makes aftermarket lockers for the front?
Is the factory rear locker controlled electronically by a button?
These come from the factory with the straight axle rear suspension correct?
Which 4x4 option is best for offroading?
Any tcase options that allow for manual shifting into 4x4 and 4 lo?
Any options come in All Wheel drive? If so, can the AWD be be controlled by a button, lever, etc.?
What amount of lift is needed to clear 35's? What is a good lift for this setup? (assume aftermarket bumpers front and rear)
What amount of lift is needed to clear 33's? What is a good lift for this setup? (assume aftermarket bumpers front and rear)
Can 33's be ran with the stock gears without issue?
My budget will be tight so I will have to take cost heavily into cosideration. (think. spacer lift, stock gears and axles, and 33's)
My cousins budget will be much bigger. He will be looking for top of the line. (think 35's with gearing to match, lockers front and rear and armour everywhere). I have no need for a rig like that since my LX450 meets those needs. My cousin justs wants something that can keep up with my Locked LX on 35's.
What packages offer a rear locker? TE ONLY
Do any packeges offer front and rear lockers? If not, what's the next best thing for the front from the factory?NO ...ARB
Who makes aftermarket lockers for the front?ARB and they make them for front and rear
Is the factory rear locker controlled electronically by a button?Yes
These come from the factory with the straight axle rear suspension correct?Yes.... 4-Link
Which 4x4 option is best for offroading? All the same with aftermarket parts as the frame to build off is the same
Any tcase options that allow for manual shifting into 4x4 and 4 lo?Only TE now but only shifts the transfer case and the front axles are electrically actuated.
Any options come in All Wheel drive? If so, can the AWD be be controlled by a button, lever, etc.?Only Limited has full time with Torsen and center diff is electrically actuated by a dialed switch
What amount of lift is needed to clear 35's? What is a good lift for this setup? (assume aftermarket bumpers front and rear)]It takes alot of work to run 35's on a 5th gen and too much to explain in a sentence.In a nutshell....Lift,UCA's ,BMC, rear bump stops and regear....See answer on running 34's ..http://www.toyota-4runner.org/5th-g...to-trail-grapplers-285-75r17.html#post1241865
Best lift....Icon ,Fox ,King ,Radflow ....research and choose your flavor.
What amount of lift is needed to clear 33's?None with a few mods What is a good lift for this setup? (assume aftermarket bumpers front and rear) You'll want a lift with stronger springs then stock for running front and rear bumpers,see answer above for best brands IMO.
Can 33's be ran with the stock gears without issue?Yes
My cousins budget will be much bigger.See build threads to spend big bucks.lol
Cheers
Awesome. You answered almost everything. Just a couple more. What came stock in the front diff of a TE? Is there any form of a limited slip or traction control system offered for the TE?
3:73 Gears with ATRAC in 4low and Trac in 4H in which is electronic traction control. Same 8" clamshell diff Toyota has used for years in their IFS and is pretty bullitproof.
Last question and then I leave yall alone and go buy a 4Runner. Is there any forums/websites that have for sale section with built rigs. If I can find one already built that is west of the Rockies then it may just be worth it to go that route instead of building a rig from the ground up. I just don't have the time to start another project when I'm deep into building my FJ80.
For enough money anything is possible. I doubt you could buy some of these on here for 50K though. Too much blood sweat and tears. Cheaper to buy new and take to 4X4 shop if you don't have time or talent.
I may have read bad info and don't remember where it was as i'm on my way out the door for work but i read somewhere that in 2010+ models of the 4Runner and FJcruiser that they switched to an 8.2" diff? can anyone confirm this?
What you're saying is with the rear diff.
Source: Toyota | 2010 Toyota 4Runner Add to Rich Heritage With More Power, Better MPG
"The new 4Runner is also equipped with a stronger rear differential over the previous model, thanks to a gear ring that has increased in size from 7.87 to 8.18 inches."
I assume that FJ and 4runner share the same diff...so, here is the official word:
"The ring gear in the 4x4 FJ Cruiser's front differential also measures eight inches."
Source: http://pressroom.toyota.com/article_display.cfm?article_id=1749
see where they say "the differential housings have improved seals for better resistance to mud and water." i wonder what they did.. some people modify the breathers on them, i wonder if it's really needed..hmmmm
Zett
