DesertCanyons
Alignment and nose dive
Yes, 3-in-1 oil. That along with WD-40 and duct tape can fix anything. I keep all 3 in good supply.
What or who are/is FK rod ends? And the frame end of the UCA is always mounted horizontally so the arm can pivot vertically with the suspension, so I don't get your meaning with that.
Thanks for the link [MENTION=104049]marshal[/MENTION]. As you may have seen (and I forgot), I read through that when you posted it. Thanks again for the detailed explanation of geometry versus nose dive. I'll still have to ponder it a while before I get how it applies to the 4Runner. Now that my new T4R TE is in my garage I think I can better visualize your illustrations.
Yes, those Camburg uniball joint caps are the ticket to dirt-free joints. Maybe Dirt King and a few others could be convinced to make and supply those. Maybe this makes a good argument for power spraying the suspension and underbody after an off-road trip? I've use the coin-op car wash bays to wash my Jeep many times.
Edit: Okay, I found the FK rod ends. I get it now. Thanks.
http://www.kartek.com/Search.aspx?q=FK+rod+ends
[MENTION=115572] ... the heim ends being mounted vertically (relatively) will fare far better. the key would be to be replacing them with high end ones when it comes due, like FK rod ends. their races are of much much higher quality and last a lot longer. 3-in-1 lube that they sell at lowes and home depot is the best lubricant you can give the joints.
that said, a nod towards icon and camburg, they both offer caps for the uniballs they use (Camburg uses a larger 1.25" uniball, the largest in the industry) that keeps the debris from entering and sitting on the top of the joint, but the bottom is still very well accessible to salt and shit
as far as anti-dive is concerned, i discussed this earlier this year with [redacted] RESQLAB. ...
http://www.toyota-4runner.org/5th-gen-t4rs/197454-bilstein-6112-5160-vs-fox-2-0-a-2.html
