O/D comes on and off while turned on
jvalasky
Just replaced my tranny and had "professionals" do it. And now O/D comes on and off. And the guy put 10 1/2 quarts of oil in it and idk if that was right or not. Any advice or knowledge will help! Thanks for looking.
driver fender square plug white has to be grounded and turn key on count the flash's. Post number and I will look in book. I would bet no.2 speed sen
Idk if I sound stupid. But could you explain the whole process to me cuz I've never done this. And will I need to buy a code reader??
A code reader won't help, these aren't OBD trucks. He's saying jump your test terminals, just like you would to pull codes from a Check Engine light, and then when you turn the key to "On", your OD light should start flashing a pattern that'll tell you what code is stored. Exactly how to jump the test terminals depends on what year your truck is and what motor it has.
Remember that Google is your friend :) - Toyota 4Runner O/D Off Light Flashing
Well I got a 95 T4R SR5 4x4 with an automatic tranny and a 3.0L V6 EFI, however, I did read your link and that's basically what mine is doing as well. So how exactly do I need to check it? Do the same as your link showed?
Yes, that's why he gave you the link.
Took a hard look today and comes out to to be a wire that wasn't not connected that the idiots missed while putting it on
