O2 sensor...important?
4RUN1T
one of my o2 sensors went the other day and all of the VSC lights are on...does this need to be fixed, my rig is running normal but i dont want to have any major problems in the future
thanks
2002 should not actually have an 02 sensor. It should have an air/fuel sensor, which if not replaced will at the least lead to problems in fuel mileage. If it is the catalytic efficiency sensor, then technically it isn't as important, but if for no other reason, I would replace it to shut the lights off so you know if there is a real problem.
When you disconnect the battery or reset the codes how long does it take to turn the light back on?
2002 models do have an o2 sensor. It's the one after the cats. The A/F sensor is before the cats.
I say fix it. They are easy to replace and will help your engine run as best it can.
a/f ratio sensor (heated 02, 4 wire 02) are before cat they are also called upstream 02s. just a regular 02 also called downstream 02 is after the cat. an issue in any of those will set a check engine light, the check engine light being on will caus vsc, and trac lights to come on. if you have a bad a/f sens I highly reccomend replacing those as soon as possible, they control the air fuel ratio through the computer, they can cause the engine to run to lean or too rich, either way can kill your gas mileage, eventually kill your spark plugs and eventually kill the cats. the after cat 02s dont have as big of an impact as the a/f but it wont be able to tell the computer if it is detecting too rich too lean so the computer can tell if the cat is good or bad.
a/f ratio sensor [O2] (heated 02, 4 wire 02) are before cat ... if you have a bad a/f sens I highly reccomend replacing those as soon as possible, they control the air fuel ratio through the computer, they can cause the engine to run to lean or too rich, either way can kill your gas mileage, eventually kill your spark plugs and eventually kill the cats. the after cat 02s dont have as big of an impact
2nd this... pre cats control a/f trims.
ok thanks guys this sounds like a pretty serious problem and i for sure want to get the best gas milage that i can. I dont think im going to take it toyota tho they usually charge too much im gonna try a toyota/import specialist
The sensor is very, very easy to replace and the parts are just as easy to purchase online. But if you have nowhere to physically do it or just don't want to then that's fine, just don't be afraid that it is a difficult job.
Which is why technically it is a catalytic efficiency sensor just as I said.
These sensors are known universally as o2 sensors, including every Toyota manual and parts guide available. There's no need to confuse the issue with
another technical name.
rear o2 sensors do nothing for the running of the motor, they simply are an indicator, they will tell you if your cats are working or not, that is it. they WILL NOT change or affect how the motor runs. ask any tech who knows about multi sensor systems like this. it will just throw a code light if it gets bad. now the down side to that is you will be accustom to the CEL being on and if you do have a more serious thing come up in the future you wont know it(unless you check your codes often) cause your CEL will already be on. the desno or NGK o2 sensor run $85-120 depending on where you get them, and are the only sensors to be used in our trucks
how sure is the op the dash lights are related to a sensor? did he even get the code pulled? just want to make sure we're not telling this guy it's no big deal and something else might be going on all together.....:zoom:
either way, if it's broke fix it.:cowboy:
all toyotas, if the cel is on, the VSC and TRAC lights will come on. it doesnt matter what the code is. the computer nows their is a code, the computer registers what the code is but the computer does not know what the code is (it knows the number but not the condition) so they are set to disengage the VSC and TRAC system just in case their is a driveability issue. when the VSC and TRAC systems are disengaged (turned off) the lights for those systems then come on. This is something I have learned in my 3 and a half years as a certified Toyota technician
yes i got the code pulled from an autozone and they told me that the part i needed would be about 179.99 is that a good price or will someone do it for cheaper?
erinobr2000
