Millersnow14
I have an 08 sr5 with a bad o2 sensor. was wondering if anyone had some advice on replacing it ,as far as tools needed and best approach to access it? it is bank one sensor 1, so upstream driver side.
thanks.
thanks.
I have an 04 with a V6. Just did both drivers side a few weeks ago. I bought both the O2 sensor sockets at Harbor Freight. Downstream was a easy, upstream was a challenge. Soaked them both with PB Blaster the night before. Ended up laying on top of the engine to replace the upstream sensor. Kind of a pain, but persistence paid off. You'll know what I mean when you get in there.
Where exactly are the downstream sensors located? Under the front passenger area? I need to replace them. Do you recall what the part # was? do both downstream sides use the same sensors?
[MENTION=87462]bgibbs11[/MENTION]
89467-71020 Upstream Oxygen Sensor (L&R are the same)
89465-35670 Left Downstream Oxygen Sensor
89465-35680 Right Downstream Oxygen Sensor
Driver side is left, so it's the car's left and right, not yours.
Finally got a chance to replace the sensor today and no luck. after replacing sensor 1 bank 1 the engine light, traction light and vsc light came back on. the codes are reading o2 sensor bank 1 sensor 1 again. Does anyone have any ideas? so frustrating! please let me know if anyone has a solution or something i am missing. thanks
