Odd Squeal/Scrape Noise
gamefreakgc
Elite Member
Alright, another one of those ambiguous "my 4Runner makes a weird noise" sort of questions. However, I'm not necessarily looking for you guys to telepathically hear the sound played over in my mind and then expect you to know exactly what it is, I'm just looking for some ideas on where to start.
The sound is originating from the undercarriage, it seems louder on the passenger side than the driver's side. It is a squeaking sound, kind of like if nails on a chalkboard (literally, not figuratively) except more of a back and forth sort of noise. It's not loud and does not vary with RPM. It only squeaks when going faster than 25 MPH but less than 60. It tends to squeak more when heading downhill or when decelerating than the opposite.
I crawled under there this weekend and tightened up all my shocks (one was loose), coils, double-checked my exhaust hangers and everything looks good. Even fixed my banged up skid plate so it can't contact the frame anymore. Also tightened the spare. Took care of some other clunks I had :) but not the squeak.
What are the main culprits here? I know someone had said transmission mounts will squeak but I'm not sure what I'm looking for there. Any ideas on most common culprits would be much appreciated.
P.S. before you ask, the noise does not pickup on a recording. It can only be heard outside when all the windows are down and it's rather high-pitched.
Everytime this happens to me I lift her up on 4 jack stands, put her in 4wd and let her turn to see where its coming from. Just be safe and use precaution and have someone inside on the brake for safety.
We also would do this when tuning our turbo cars in the garage. Could keep the brake on and tune specific rpm more easy. Lets just say neighbors would complain 9pm tuning cars that sound like jet engines. LOL.
After another evening of tinkering around, I found it. I sprayed some penetrating oil on the tops and bottom of the front coils and no more squeak.
MaximussK
