OEM Ball joints - what comes with them
Ghostrider
Registered User
Several posts reference replacing the bolts that hold the LBJ's but the parts diagrams do not show any bolts. Do the bolts come with the LBJ's or is there a part number
I got a set from camelback and no bolts came with them. I can find the part number for the bolts if you need
I did not get bolts with my LBJs. I got the ball joint pressed into a carrier and a castle nut and cotter pin.
You can get metric bolts at any hardware store. They're likely to be a 15mm or 16mm head though, so if you have to replace them and you have to have a 14mm head, they're probably a buck each from the dealer.
I had to reuse my old bolts(x4). Ordered the OEM LBJ from Toyota. I did use loctite on them. So far 40,xxx on the new LBJ's and 251,xxx on the truck.
Might have to take one of the old bolts to a hardware store and match up a new set of bolts. Or others were lucky enough to receive a new set
Thanks for the part numbers. I had used that thread before orderingbut it did not list the bolts.
Are all the bolts the same length? For some reason I remember a thread that indicated they were not
It does lists the bolts and from what I can tell by looking at diagrams, its the same bolt. I can let you know for sure in a week.
Mine just showed up today from ToyotaPartsZone with no bolts included.. I would be interested in picking up the bolts as well since it would be nice to start with all new bolts. There are ones listed on the OEM Part Number pagehttp://www.toyotapartszone.com/oem/90080-10066.html
Im guessing these are it since they are listed as the LBJ bolts.
Those are the correct bolts. Yes they are all the same size.
