OEM Battery life?
vicpick58
Hi all, my 2012 will be two years old soon, and I was just wondering how long can I reasonably expect the factory supplied battery to last?
I had not bought a brand new vehicle since 1998 and in the old days a factory battery would last four or more years depending on how many times it happened to get discharged.
But in the last 10 years or so it seems that various aftermarket batteries that I have had only seem to last a couple years. I even had one fail exactly two years to the day from when it was bought, warranty replaced it, then the warranty one failed two years later.
I use a label maker and mark the install date on all my vehicles batteries so I know how long they have been in service. I also look at the date code on the battery when buying one to make sure it is no more than 30 days old because I have heard that sitting around on the shelf with out being charged can shorten their life.
I hate to have a battery failure in the middle nowhere in the middle of the night in the rain. So I have been changing them out every two years for a while now to keep that unexpected failure from happening. But that was in Jeeps, Dodges and a Lincoln, I have a 4Runner now and the wife now has a used 2012 Avalon that I bought a couple months ago.
So do these factory batteries last a while or should I be looking into replacing both the 4Runner and Avalon batteries soon?
Actually after thinking about it, I probably should replace the Avalon one since I don't know if it has ever been discharged, but I KNOW the 4runner battery has not been discharged since I bought the vehicle new.
Actually after thinking about it, I probably should replace the Avalon one since I don't know if it has ever been discharged, but I KNOW the 4runner battery has not been discharged.
It really depends a lot on your climate (in addition to how you use/maintain it). Since you've said you never drained it down, then it's pretty much up to how hot is your area? In mild climates, I've easily gotten 6-7 years out of these OEM Panasonic batteries. They are pretty durable batteries!
However, I've heard time and time again, in the real hot climates no battery lasts more then 2-3 years...so, I would probably just load test it once a year if you are worried and play it by ear.
No sense in throwing out a perfectly good battery you know :)
Thanks eddiebx, it does get pretty hot around here in the summer, however the last couple have been relatively mild. I do hate to throw away a perfectly good battery, but I also hate to have one quit on me.
Just kind of trying to get some idea of how these Toyota batteries hold up. I would have to assume that at least some 5th gen owners have had one fail by now.
2011
Hey, Vic.
I have a 2011 and have yet to change my battery. Never has start up stalled nor has the battery ever drained on me. I live in the most climatized area in CA and not to mention, all of US so this may be subjective. However, I say the track record speaks for itself.
I hole you get a good sampling and are instilled with confidence on how long to keep the OEM battery.
Super impressed with the Panasonic batteries! Just sold my 07 FJ with original battery and it showed no signs of getting weaker. I live at 8200 ft in Colorado and it sat outside all the time.
all my Toyota batteries have lasted a long time. (current Avalon is like 6 yrs old batt, and 4runner is on original and doing good) i also don't drain them dead often. maybe once with each vehicle. my 4runner is regularly at 13.9. and i have left a light on all night long and it was fine in the morning despite it being 20 degrees f" out
I live in the "greater East Bay area"= the Tri Valley"; my 2010 TE bought in March 2010 with 68,800+ miles has been parked outside the whole time and it starts up each time with no problems just like when I first bought it!
Thanks for all the replies, this information puts my mind at ease. I will not worry about the battery for a while.
However, I've heard time and time again, in the real hot climates no battery lasts more then 2-3 years.)
I've also heard that, and sold a Tahoe to someone from Las Vegas whereupon the battery failed almost immediately. Does anyone know the science behind what would cause this?:noidea::noidea:
The OEM in my 98 4R lasted 13 YRS. I think it would have gone further but I left the key while doing something . After that it never was trust worthy.
Now the two year old D
Duralast is near death.
Yeah Duralasts are some of the ones that only lasted two years in my Grand Cherokees.
I have a 2010 Sr5 which I took possession of on February 5, 2010. I live in the Philadelphia, PA area and have driven all around the East Coast, and done a lot of downhill skiing in the East in all types of climate. Still have OEM battery, with no problems. Have a '14 Trail on the way to replace a very reliable vehicle. You should be fine. Good luck.
How about using a Battery Tender (or similar product) to help extend the life of your batteries? Doesn't a fully charged battery last longer, as it reduces the damaging effects of sulfation and keeps the cells in good condition longer?
I haven't had my Runner long enough to worry about the battery much, but my 2007 IS350 is still on the OEM battery.
Philthyphilthy
