OEM Brake Parts List
Chilow
Preparing to replace my brakes with OEM parts. I know some of the parts listed below can be reused, but I'd rather just have them available in case the old parts are rusted out or unusable. Can anybody confirm the following parts and #'s are all that's needed?
-Front Brake Pads 04465-60320 (Quantity:1)
-Front Brake Pads Retaining Clip 04947-35050 (Quantity:2)
-Front Brake Pads Shim Kit 04945-60090 (Quantity:1)
-Front Caliper Pin 90240-06158 (Quantity:4)
-Front Caliper Pin Clip 47743-60280 (Quantity:2)
-Front Rotors 43512-60191 (Quantity:2)
-Rear Brake Pads 04466-60140 (Quantity: 1)
-Rear Pads Shim Kit 04946-60141 (Quantity:1)
-Rear Brake Fitting Kit 04947-22050 (Quantity:1)
-Rear Rotors 42431-60311 (Quantity:2)
Do the front brakes have a "fitting kit"? I noticed looking at pictures from brake jobs for the 5th gen doesn't show existing hardware for the brake pad "ears" to slide into.
The front brakes don't have a fitting kit like the rear brakes do as the calipers are totally different. The front pads drop down into the calipers from above and are held in by the slide pins and clips. The rear pads slide in from the sides of the caliper brackets onto the fitting kit parts.
Thank you for the reassurance.
