OEM TRD Pro Performance Exhaust - Is it Bolt-on?
hicucr
Hi all
does anyone know if the OEM TRD Pro Performance Exhaust, part number PTR03-89200, is a bolt-on part?
the shop that I want it installed at is asking if it can be bolted on or if needs welding because they don't do welding.
thanks
Yep, bolts right on. However a lot of people complain about the drone
If any of those people are in the greater Utah Wasatch Front area, I'll happily take their TRD PRO exhaust off their hands for at least $100, maybe $200!
*And I'll be keeping my OEM exhaust, just in case I end up hating the TRD exhaust!
Not saying you won't get lucky depending on mileage and condition, but I wouldn't hold my breath finding one that cheap that is in good condition.
If you are doing the entire exhaust it will bolt right on, but if you are just doing the muffler portion; it will not. Size is perfect, but the flange on one end is different. 2 hole vs 3 hole. I just had it done ... went from Pro to OEM. I wanted to keep the Pro look with the side exit, so I just replaced the muffler portion to quiet it down a bit.
Bunkstaff
