OEM turn signal fast clicks
Okki
When turning on my passenger side turn signal, a lot of times I get a couple fast clicks (and I assume blinks) and then it goes back to normal. Driver side is normal.
I checked the blinkers and it appears that all are working correctly (they blink). I read that some cars do this to indicate a bad/dead bulb, but mine appear fine at the moment.
Anyone any experience with this?
Thanks and have a great day!
Okki
Swap bulbs from side to side and see if the problem follows the bulb. Sometimes it is hard to see.
passenger side fast
I'm seeing a pattern in these blinker posts -- passenger side.
Mine was doing the fast flashing on passenger side (no light outside). Bulb change no help. Saw posts about the switch. Whenever it acted up, I noticed it would begin to flash correctly if I moved the switch to high beams.
Assuming there's some corrosion / buildup, I did this:
Rapidly move the switch between right and center about 20 times.
Repeat in High Beam position
Repeat in High Beam flash-to-pass position
I know it's probably not a "fix" but it's been working fine for 2 months.
delislerebecca
