OEM vs Aftermarket u joints
papapoopski
I will be replacing my rearmost ujoint soon. Any opinions on aftermarket vs OEM?
I don't have a preference but I also don't know enough about the driveshaft. I like saving money. NAPA is 5 minutes away. BUT, I've spent the extra for OEM on other stuff like steering rack, etc.
I would say stick with OEM. I had my rear u-joint go out on my 2000 2wd and was talked into an aftermarket with grease zerks as the 2wd versions are factory sealed. I was never able to get a grease gun attachment of any kind on those zerks and had a bad vibration over 60mph. Went as far as putting a whole new driveshaft (aftermarket) on and still did not get rid of the vibration. I got fed up and had OEM drive shaft and u-joints put back on and it was smooth sailing from there on out. Morale of the story is I spent a lot more money and frustration in the end not going with OEM. YMMV
I have not yet needed to replace my u-joints, but the driveline becomes a point of frustration for many people. I think it may be best to stay OEM on this one.
OEM or good used TOYOTA drive shaft. I pulled a used drive shaft from 300+ K miles truck and it was as good as new. If you maintain it right it goes a long way.
Used drive shaft? He's replacing the rear u-joint, not the double cardan... buying a whole new DS is a ridiculous solution to needing to replace a normal wear item, especially considering the u-joint in the used DS will be used too with who knows how many miles on it... I mean i'm glad your's has worked out for however long you've had it, but that is not a solution to the OP's problem.
IMO, go with whatever. The OEM is showing up for me as $50, I got a Moog one for about $15 and it has been fine for I think about a year and a half so far. The OEM isn't THAT expensive, so go for it if you want higher quality, but certainly don't buy a used drive shaft.
It is a straightforward install of you have a press, or still straightforward for any shop. you can take the DS off the vehicle yourself and take it in making it cost alot less than if you just take it to a dealership.
I had moogs fail on my bronco in about 15k miles. My driveshaft failed around 250k miles. Pulled a used 150k mile shaft for $25 and running like a champ.
Yeah, Moog is by far not my favorite brand, I have bashed their stuff pretty hard in other threads, but I needed to do the fix that day, so my options were limited. I know that I bought the convenience with lifespan.
Really, the swap out isn't that bad, so if it fails prematurely, I'll just replace it with a better OEM one. At least the u-joint doesn't fail catastrophically like LBJ's do.
I will say though that I am well beyond 15k on mine, but I'm not going to go out on a limb to vouch for Moog either. My original u-joint (I assume original) failed around 150k. If my moog fails early, it'll probably be because I don't lube it as frequently as I should.
Yes that is so true, I had a driveshaft come apart on my 400hp Talon back in the day. Not fun, entire undercarriage was dented, floor pan was so messed up. LOL. I did get to do it front of a Lotus Elise (slow) and an SVT SC Cobra Mustang (kind of quick) which made a fun story.
Guy in Mustang stopped and gave me ride home. He was getting paranoid the closer we got. I was kind of confused. Long story short once we arrived he was relieved because I guess he was having an affair with the women across the street years before and thought I was the husband!!! LMAO. Was great.
HA! Nice. I guess that's good evidence that these are never really over, so keep it in your pants unless your wife lets it out gents... Pretty hilariously random though.
I wouldn't think that it would bounce around that much, but I guess that with it bending at the DC, you would get some decent moment on the DC pushing it to whip around.
I think it is very unlikely that you will get a separation failure with a crappy u-joint, I think it will just wear out early. I was surprised to find that my rumbling u-joint was missing a lot of needles from 2 out of the 4 bearings. I didn't think that it was nearly that far gone based on how much it rumbled.
My Talon normally had a 3 piece driveshaft that ran a long distance for how small the car was. I had an aftermarket 2 piece shaft that had gotten bent previously (we wont talk about that) at the DC. I didnt know it and at high speed the shaft was unbalanced and the DC ripped out its mounts. Was not saying it was from bad u joints. Just saying its not fun for a shaft to fail like that. The Lotus said he had to dodge junks of asphalt flying at him.
according to my driveline guy, and various other people around the world, OEM Toyota U-joints are hard to beat.
they are some of the strongest out there, and will operate at a much higher angle.
now, whether the aftermarket joints are built to the same standards, I have no idea.
but I do know, I had over 250k miles before I finally had to replace a bad joint. and im certain had I maintained it better, it would still be good....
When something needs to be replaced on my truck I go OEM or better. Yes, you can buy better than OEM for less money on some things (like my drive shaft). I would look at Tom Woods Gold Seal U-joints. They're only $20 & guaranteed for life. Thats less than 1/2 of a OEM u-joint.
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
Yeah, I don't know. No aftermarket company can spend as much money developing each gen/model specific component as the OEM can. That could result in specific geometric issues causing less articulation than the OEM. Or, if you really have a good aftermarket company with some actual intellectual property in their product, they might be able to make something better. Unless you are replacing a whole system though, I would just stick with OEM.
I think OEM will tend to have better materials than aftermarket. If Tom's has a good warranty though, that can be useful in and of itself.
I agree but Toyota isn't perfect. It doesn't look like they did much research on their LBJ's, or dash clock! LOL Go to Toms website & read the warranty, if the u-joint fails & messes up your drive shaft, they will replace it. Lets see Napa or Toyota do that. They make drive shafts & joints for off road vehicles, they can add articulation. Check out their website.
H.Sikina
