OEM wind deflector/bug shield, pics please!!
spitvenom
ive searched but have not yielded great pics, I have a AVS ll right now but was looking to see if I like the shape of the OEM one more.
the more and higher res pics the better.!
this what your looking for?
IMG_2970.jpg~original
IMG_2971.jpg~original
IMG_2972.jpg~original
IMG_2973.jpg~original
Yes that is what I am looking for, does it slope up in the middle? so the bottoms are open at some points I see hmmm It looks indentical to the AVS ll from those pics.
I too have OEM ones, these are the only pics I have. That is the OEM sunroof visor as well. I can get more pics if you need.
no that ok, thanks for the offer though. Thanks guys, I guess its pretty much exactly like the avs one so I am just getting a new one of those.
There is a much more slim-line OEM version that my mom had on her '99 but it was so close to the hood it was hard to clean behind and bumpstops were mandatory and as soon as my mom lost one of those it started rubbing the paint real bad so now she has the AVS one which requires no bumpstops.
Tip: Just to share with you that if you hear any whistle sounds thinking it's from the OEM shield, it's most likely coming from the top black weather strip area located near the very top of your windshield. In my case, a small amount of permatex clear silicone windshield/glass sealer ($5 on amazon) sealed things up and took care of the annoying noise.
Here's my Toyota OEM bug shield:
photo2-1.jpg~original
I have a chance to buy a OEM Bug shield locally but doesn't come with hardware. I think I will only need the screws but does anyone know? Seller is asking $40 but think I will ask for a lower price w/o the mounting hardware or is this a fair price?
Nope.
I actually ended up buying one from the dealer and went through the install last weekend. I would strongly caution against buying one without the mounting hardware unless you can get it directly from Toytoa. You may want to check with the dealer as I am not sure if you can order up just the mounting hardware without the shield (mine came as a kit).
Instructions for installing the kit are here (http://toyotapart.com/PT427-89011.pdf), and you'll quickly see why the mounting hardware is a pretty key item for installing the shield. (see post below)
I actually ended up buying one from the dealer and went through the install last weekend. I would strongly caution against buying one without the mounting hardware unless you can get it directly from Toytoa. You may want to check with the dealer as I am not sure if you can order up just the mounting hardware withouth the shield (mine came as a kit).
I'll post up a PDF with the instructions later today, and you'll quickly see why the mounting hardware is a pretty key item for installing the sheild.
Cool and Thanks,
How much was the shield from the dealer?
info
Price from the dealer was about $70 after tax. It looks fantastic too. I would very much so recommend that you buy from the dealer or online and avoid a used piece. The plastic is very clear and has a nice new shine to it.
Toyotapartszone.com currently has the shield for $67.21 prior to tax/shipping.
Here is a link to the installation document http://toyotapart.com/PT427-89011.pdf
Note that no Toyota part numbers are listed for any of the screws (you need 4), inserts and washers (total of 12) or the rubber bumpers that will keep the shield from messing up your hood (you get 5, but only need 4).
Here is a link to someone who recently did the same thing that I did and has tons of really nice photos from the install.
http://www.toyota-4runner.org/3rd-g...g-shield-whistling-noise-driving-me-nuts.html
And for anyone else that is interested:
Toyota Part Numbers:
PT427-89011 Hood Protector - base and SR5, Limited
OR
PT427-89990 For Sport Model 4 runner only (Hood scoop)
Cool and Thanks,
hardware may be available...
I stand corrected... It looks like you can just buy the mounting hardware... Toyotapart.com has it listed as part number PT427-89011-HW. I'm not sure what comes with the kit, but it's going for $6.19 on their website. Also, the whole kit is $68.48 at Toyotapart.com
OR
When I bought mine it had rock chips all over the front of the hood. Instead of spending $40-$70 I spent $8 on Bedliner spray, taped off the front of the hood and covered it up. I am not at a computer with my pictures but will post them when I get home tonight if you like.
***Edit*** Actually the pictures are in my album here. I forgot I posted them.
DJNutshell
