Oil filter leak. 2006 V6 new Mobil 1 filter
nick168
I noticed a leak from my filter it’s not crazy but it’s causing a drip.
It’s a new filter it’s Mobil 1. Pre oiled gaskets. Tightened by hand? Any reason why?
Did you make sure the gasket from the old filter was removed? If so just snug it up some more by hand.
I agree with the guys above. Get a new filter then pull that one off and make sure the mating surface is clean. Not worth having an oil leak over a less than $10 filter.
Another reason to stick with Toyota OEM oil filters. I've never had an issue with an OEM filter in my 15 years of 4Runner ownership.
They are super cheap too. I get them from my local dealer for $5.87 each. Fram at Walmart costs more than that lol.
+1.
The one and only time I used a WIX filter it failed. Long story short, I started to have an intermittent low oil pressure light coming on. Turned out to be the oil filter clogged or failed (approx. 300 miles after oil change).
I am dealing with O'Reillys right now and will post the outcome as soon as it is finalized.
I also used the OEM filters and won't use anything else, for both of the reasons stated above.
I buy mine online and 3 to 5 at a time depending on what else I maybe ordering and get them for $3.75 each from McGeorge Toyota!
I had the same thing happen awhile back on my 2001. Turned out to be a tiny grain of dirt or whatever. Removed the filter, cleaned both surfaces and re-installed.
Same. I did this a couple months ago and it came out to about $3.50 apiece. I have nine left. OEM for life in the case of oil filters for all Toyota trucks. Buy them shits in bulk and forget about it.
I have always asked the Service guy to put the longer truck filter in it, no problems.
______________________
2007 SE V6 Titanium
AndiGarage
