Oil pressure gauge
torynich
OK, I have a couple of questions here about the oil pressure gauge. I installed a replacement engine in my 87 4runner out of a 85 4runner. When I started it, everything worked fine except the oil pressure gauge...it kind of jumped around a little bit and then just slowly went down to zero. I installed an aux. oil pressure gauge and verified the engine is making oil pressure so I removed the 85 pressure sender and installed the original 87 sender, but the gauge still doesnt work. after some research, I see that there is a difference between the sender for the idiot light and the sender for the pressure gauge. On top of that I read that if the wrong sender is used it can fry the cluster gauge....this is where I think I am at. My questions are: how to tell the difference between the sending units, and what can be done about the gauge? Can it be repaired, individually replaced, or do I have to get a complete replacement cluster? (I never saw the donor vehicle so I cant verify if it had a light or gauge)
This is the base on/off oil pressure sender
88-95WarningLightOilPressure.jpg~original
This is the SR5 sender, it's much bigger
Gaugecluster14.jpg~original
Far as I know, once you fry that gauge, it's fried. It might be replaceable, but I bet it'd be easier to get another cluster or just run an aftermarket dial gauge.
Why not pull your gauge cluster out and see if you can take it apart ?
Then you'll now if the oil press gauge can be removed separately and possibly repaired.
yep...I'll be tearing in to it. I bought the truck with a bad motor, so I dont know if the oil pressure gauge ever worked. Looking at the pics KidV posted I have two on/off senders. The pressure gauge probably never worked then. Now I have to decide if I want to put in an aftermarket gauge or get a sr5 sender and hopefully maybe fix the dash gauge...an aftermarket gauge is gonna be cheaper, but mounting it might in an aesthetically appealing way might be tough...
thanks for the help guys...
