Oil question
hec983
I just bought the runner 99 with 128k and I changed the oil to pennzoil ultra. Now I dnt know what the original owner used probably conventional oil. Would it hurt anything the change??
Absolutely not! Just make sure a good filter and keep changing frequently whatever your intervals may be.
Dave
did you also change the gasket along with the new Toyota filter?
Just curious. Do we need to change the gasket with each oil change? I dont change the oil myself and have to rely on the local garage to do that, wondering if they do that.
I doubt they change that gasket on the oil filter unless you provide it to them yourself and specifically ask they do so
new filters come with a gasket. what do you mean change it? i've never bought a filter without it.
I was going to ask the same question.
When you go to the dealer to ask for a gasket. The only thing that makes sense to me is asking for the crush washers for the drain plug.
I use aluminum or copper washers
There is some confusion here, methinks. Some are talking about the drain plug gasket (90430-12031) not the gasket on the filter itself. I also have never seen a filter that came without its own gasket.
The drain plug gasket is different. Manual recommends it be changed every time and that is best practice. I have never had a problem using one twice and I never do more than twice. Mostly I change them every time if I have one available. I have taken off ones of an unknown age installed by PO's or other mechanics that were in pieces or leaking due to excessive compression from multiple torque-downs.
As far as cyclops13, ask your mechanic what he does before the next change. I'm sure a lot of them change out with generic washers. There aren't that many sizes. I'm also sure there are plenty that will reuse beyond what is ideal.
Amazon sells a 10-pack.
Amazon.com: Genuine Toyota - Oil Drain Plug Gaskets (QTY10) - 90430-12031: Automotive
are those plastic or aluminum/copper?
DexterShaYang
