Oil suggestions for 4runner
Where did you hear going back and forth will gum up your engine? Synthetic oil is designed to work with conventional oil. Mix them, match them, run whatever you want, however you want. Just do it.
5w30 is on the cap, and in the manual. If we're talking brands, I like mobil 1 full synthetic. Just know that if your car has a leak somewhere, then synthetic oil will drip through the leak faster, and make it appear worse. That's what happened to me, and it showed me that I had a valve cover leak.
Source:
Eric the Car Guy Conventional vs Synthetic
I will rephrase my statement. - I dont mix or go back and forth between oils because I feel the my vehicle becomes accustomed to one type of oil and mixing oils with different flow rates can cause it to become confused, skip, drool and bark. consistency is key.
Maybe once. But lets be honest, most name brand oil makers have added the good stuff already.
The only thing lucas oil is good for is if you need to thicken the oil for the pump to pick it up.. but if you are at that point; your engine is sludged up and your pump is dying.
Better to fix that than use lucas.
Modern conventional and in particular synthetic is all you need.
Opps: I was talking oil. Lucas makes an oil add on.
Fuel: Sure. There are some additives that can help. Don't use any with the expectation of performance increase, but some that prevent water build up or help stabilize over a long period of not driving work great. There is no miracle in a can...like extenze for a car, they don't work.
