Ok new guy here please help
johnlovett
I am trying to find out what years have the highest and lowest suspension from the factory thanks and yes i looked but could not find it on the forum.
Highest - 1999 Highlander
:banana: :whoo: :trophy: :biggrin1:
where can we find measurements on this?
I took the measurements from my Stock 97 Base 2WD springs, they measured out 2" lower than the "Normal" 4WD springs from the era, measured at the junkyard, it sat noticibly lower than any other 3rd gen stock. My 5100's and Tundra springs netted me 5.5" of lift over stock.From around 22" to 27.5" Hub to fender (3" Bl already on for both)
The highlander springs are just kind of common knowledge on the forum, no actual experience there from me.
The Highlander has the same springs and suspension height as most '99's that had 16-inch wheels from the factory, including mine. (I used to say all, but one guy argued with me based on his rig. I didn't really believe he was 16-inch from the factory, though.)
Part Numbers:
Front right 48131-35400 L=368mm
Front left 48131-35350 L=374mm
Rears ( same for both ) 48231-35210
Color Codes:
Fronts: Blue/Pink(left) & Blue/Yellow (right)
Rears: Green/Red
thanks, im trying to increase mine becaue i feel its not much higher than stock, its a little taller noticably parked next to one, but if it was not you wouldnt notice its lifted.
i have a 2000 limited with king coil overs and toy tech superflex in the rear. it sits level. i would raise it up more but it would throw off the rear.
My current measurements are (with limited flares) are 23.75. THIS IS BULL S***.
Mike Sargent
