Old man needs HELP
oljedi11950
Sorry boys gotta be a better way to extract broken bolt than drilling , any secrets my f^%$ arms are sore from laying down doing this (front sway bar bracket bolt) ?
How long has the bolt been there? You could blast it with Deep Creep to help loosen it up a bit. Are you using a standard drill bit to try and extract it, or a left handed bit? I have pulled broken studs with left handed drill bits before. Find one that is about half the diameter as the stud you are pulling. The left handed torque of the drill bit may back the bolt out enough that you can put two nuts on it and back it the rest of the way out.
Well probably not to long since I installed FJs & 51s 5k maybe , gotta nice hole drilled . Should probably go slow & not get frustrated , gonna run up to pepboyz & look for cpl lefty bits thanks
Well lette me splain it ! 1st have Miller lite , then right tool , copius amounts of PBBlaster , soak , extract , mother F#$%^& , that killed this ol'man , the trip to pepboys , bought the right extracter came right out & the 3 hrs drilling into it . Thanks to all the brothers with positive vibes !!!
Talyn
