Older GX low profile bumper on pre facelift 10-13 front end
earth1
Attempting to use this crap forum- because it is the most active and archived, and I thought OG owners would like to see another winch bumper option. I'm not sure this has been done before, at least I couldn't find any photos.
As many of you know, we early 5th gen peeps are SOL in the winch bumper market. I tried lots of bumper manufacturers to beg for a custom width low profile bumper, like modifying one of their existing designs- no luck. Not even from anyone who used to make them. I couldn't find anyone who would even make me one locally. I considered buying a 14+ hybrid bumper and cutting width off of the fascia/ having plate welded to fill it back in. That would have been over $1,000 new. I definitely didn't want a full bumper, or just a winch plate. I like the early 5G look and really just wanted a low-key winch bumper with recovery points. Trying to keep my rig unsuspecting and simple looking with just enough tasteful mods to use it like I want to.
After combing the classifieds for 2 years, I finally found an older LFD GX470 hybrid front bumper on marketplace. Took a chance, and it bolted right up. It's a decent fit, not perfect- but I can live with it. I needed to add 1/2 inch of plate steel to the frame horns for spacing the LFD bumper to line up with my plastic cover. It appears that GX bumper sticks all about a half inch less than mine. I picked up the bumper for $350, did a decent refurbish - cleaned up the welds, sanded it, treated surface rust where powder coat was starting to fail, and sprayed it with 2K paint and 2K satin clear. Badlands 12K winch fit with no relocations.
For anyone researching bumper options, that 03 to 09 generation GX470, maybe 460 also- the frame horn mounts are exactly the same as 5th gen 4runners. I hope this opens up more possibilities for those of you looking to retrofit a lucky used find.
FYI, my rig is a 13 Limited with Trail Edition rockers and rear bumper, and Canadian SR5 front bumper. That front bumper is the same as the TE, minus the mounting holes for the front Bull Bar garnish thing. I would never have paid full price for that swap, but my rig was nearly totaled in front of my place- requiring nearly every trim piece be replaced. For the rebuild, I had the body shop dress it up like a 10 to 13 Trail Edition. This should probably work on any 10-13 though; LE/SR5/TE with the right amount of space between the frame horn ends and bumper.
I like that idea. I too have had no luck finding 10-13 bumpers for winches. although in Canada I need a front license plate. is that mount you have for yours custom made, it looks to stick up a bit higher. I don't think my plate would fit with that bumper
You are correct. It's a license plate mount for a Camry that I modified. Not in the best spot now with the bumper hoop. I've thought about trying something different, but probably won't because of the holes there now.
if it's legible I wouldn't bother changing it. it looks good the way it is. looks legible from the pic even with the bar there. I really want a winch but I just don't think I will be able to find a solution that works and is economical. shipping that heavy steel from the states is costly...
Earth1, Thanks for the post. I found a used C4 2014+ Low Pro bumper and was wondering if that was one you looked at and if so what you meant by "cutting width off of the fascia/ having plate welded to fill it back in."
I am mainly concerned with the angle of the bottom portion not lining up with the plastic maybe that's what you mean.
Anyway any information you can provide would be greatly appreciated, I can tell if it would work just looking at pictures. It does look like it will bolt right up. I am mainly concerned will it look weird with the sloped angel of the lower section not matching the bumper plastic on each side. Hopefully it will line up with my LFD skid plate on the bottom.
PS. My 4Runner is a 2012 Trail
Earth1, Thanks for the post. I found a used C4 2014+ hybrid bumper and was wondering if that was one you looked at and if so what you meant by "cutting width off of the fascia/ having plate welded to fill it back in."
C4 hybrid and overland bumpers will fit 10-13 4runners even though C4 doesn't advertise it. They were originally only designed for 14+ but there are photos online. We may be limited to the pre-runner and no bull bar configs. Seems like OP was referring to modifying a C4 hybrid bumper and cutting off the side tubes to create a make-shift center winch bumper, not a true lo-pro. I actually was one of the few 10-13 4runners that owned C4's lo pro when they briefly released it a few years ago. I am now running their rock runner bumper
Thanks for the reply. This whole thing is confusing , I misspoke I should have said I found a used C4 Low Pro.
Anyway I am just trying to save some money with a used one like to OP.
I would prefer a full metal bumper but I don't like to expose all the stuff behind the plastic and almost all the offroad bumpers are extreme high clearance exposing suspension water bottle and more. I did find one I like but its $2700, (Made by AFN ). I just want a bit more clearance and clean look. I wish I had a fab shop to make my own.
I highly doubt the 14+ lo pro will fit body line wise without modification. I am sure someone has tried, but the problem is the 10-13 market is so low compared to 14+. That is the reason most companies drop the design or market towards to face lift 4Runners only. I think over 100+ members signed up for the C4 10-13 lo pro, but only like 30 of us actually purchased them.
I didn’t necessarily gain more clearance with C4s lo pro as it aligned with the bottom of the Trail bumper. I gained a bit of clearance going 34s but the lo pro did provide extra protection, which I did smack on more technical trails, and a location to mount a winch. I would say you gain a location to mount a light bar, but I have a 30” mounted behind the factory grill so you can kind of cross that’s out. But remember you are more adding about 60lbs of steel up front without a winch, so you have to consider adjust preload or going a bit stiffer on spring set up. But if you just want a winch, BudBuilt makes a hidden winch mount for our years. There’s a ton of things to consider with modding a vehicle, I typically spend days if not weeks researching before purchasing let alone modifying my truck
