OME 885 measurements for V8
JeratBP
Member
Can anyone confirm my current measurements? I have no plans for new UCA's but I'm 4" taller in the front, and I should only be 2 1/2" higher.
'05 V8 Sport
Installed OME 885 w/ Nitro Sport, assembled by Toytec
Measured from ground to fender:
Stock front: 33 3/8"
Lifted: 37 3/4"
Toytec RCC2.0 w/ Nitro Sport
Stock rear: 36 1/4"
Lifted: 38 1/2" (38 3/4" pass side)
Were my XREAS just 1 1/2" lower to start with?
I had a Daystar lift on before I replaced my suspension with OME 895/ToytecRCC2.0HD's. I did not run Nitro's, but perhaps these measurements will help as the springs should provide your lift. I measured from center of axle to fender in my 04 which eliminated tire size variance. I also have a trim spacer on driver front. The ToytecRCC2.0HD are 1/2" taller as well as a bit stiffer than the rcc2.0's. I am in an 04V8 SE.
Hope this helps.
Center of Axle to Bottom of Fender
DF - 23
PF - 23 1/4
DR - 24 1/2
PR - 24 1/2
I'm guessing your Xreas was shot. That's roughly my measurement as well. I am at 39" front. Take the 1/2" from top spacers, height of 285/70's out of the equation and I would be at 37.75-38"
I have 885s and 5100s. My measurement from the ground in the front is 38 1/4". From hub it's about 23.5"
So we're about a half inch off and I have a tire an inch bigger than stock. Thus, I think you're fine.
Thank you!
I just did 885's and 895's with bilstein 5100's. 265's to 285's.
I went up about 5-6 inches in the front, close to 40" ground to fender. I think my xreas was pretty saggy, 223k on the clock
