OME 891 or Tundra or LC rear coils etc?
So if I want to go the mid-lift route, and run 906s in the rear, what would be best for the front if I am running an aftermarket, (Shrockworks), bumper?
I have been going back and forth on different lift options and combinations reading as many different treads as possible. I started off thinking that 99 talls would be good but then I got thinking about the additional weight of the front bumper, and figured the 99s would not be the best route.
With a heavier front bumper, you'll want something beefier than the 99 talls and if you're doing a bit of a lift you'll probably want something a bit taller than the 901's.
I am running the OME 890s and while they give me the desired lift I want they also ride good. The only downside is after loading up the back with gear, the rear sags noticeably:sad:. I will be looking to the 891s when I have the $$.
alexaturner
