OME Springs / Question
Poorboy64
I think I have the answer but looking for real world input,Been looking at all the threads on this I think I have confused myself.
99 4wd limited, Don't know what springs the PO put up front, OEM 99 talls were in back, The front sat 1.5 to 2" higher, installed OME 2906 in the rear but the front is still 0.5" Currently From hub to bottom of fender F=22" , R=21.5"
I'm thinking if I put OME 2881 up front should give me a nice 0.25" rake?
Is this correct or would 2880 be my best bet?
My goal is to level the truck out.
Also would going to 265/75 tires lift the truck even more? I like the height of where the rear is sitting.
Thanks,
With 99 talls on the front and 906 in back I was sitting just about level. Once I added a bumper and winch on the front I got the rake I wanted.
I would not expect rake with 906 in the back and any kind of lift in front, if anything you’ll be about level. Good thing is the 906 holds weight in the back well and doesn’t sag much with passengers + gear.
AndiGarage
